CD - Brennfehler
Recommended Posts
21:21:43 #8 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 234559 (52:09.34)
21:21:43 #9 Text 0 File DlgWaitCD.cpp, Line 234
Write in overburning mode: FALSE
21:21:43 #10 Text 0 File DlgWaitCD.cpp, Line 1694
Recorder: LITE-ON LTR-52327S;
CDR code: 00 97 22 67; OSJ entry from: Daxon Technology, Inc.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 16 43 (LI 97:22.67), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
21:21:44 #11 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder LITE-ON LTR-52327S for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD not fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 480686080
21:21:44 #12 Text 0 File ThreadedTransferInterface.cpp, Line 852
Removed 2 run-out blocks from end of track 1.
21:21:44 #13 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 234560 (234560) = #234560/52:7.35
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 234558 blocks [LITE-ON LTR-52327S ]
21:21:44 #14 Phase 24 File dlgbrnst.cpp, Line 1655
Cachen von Dateien
21:21:44 #15 Phase 25 File dlgbrnst.cpp, Line 1655
Cachen von Dateien fertig
21:21:44 #16 Phase 36 File dlgbrnst.cpp, Line 1655
Start des Brennvorganges mit 24x (3.600 KB/s)
21:21:45 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
21:21:45 #18 Text 0 File Mmc.cpp, Line 19030
Set BUFE: supported -> ON , SMART-BURN : ON
21:22:08 #19 SCSI -1135 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02600000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0xE0 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
21:22:08 #20 MMC -1135 File Writer.cpp, Line 333
Write error
21:22:08 #21 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
21:22:09 #22 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
21:22:09 #23 CDR -201 File WriterStatus.cpp, Line 194
Ungültiger Brennzustand
21:22:09 #24 TRANSFER -18 File WriterStatus.cpp, Line 194
EndTrack fehlgeschlagen
21:22:09 #25 Text 0 File Mmc.cpp, Line 14023
<LITE-ON LTR-52327S > start Close Session
21:22:12 #26 SCSI -1176 File Cdrdrv.cpp, Line 1241
Sense Code: 0x72
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x00
21:22:12 #27 MMC -1176 File WriterStatus.cpp, Line 233
Session fixation error
21:22:12 #28 TRANSFER -19 File WriterStatus.cpp, Line 233
Fixieren fehlgeschlagen
21:22:12 #29 Text 0 File WriterStatus.cpp, Line 242
falling back to disc fixation
21:22:12 #30 Text 0 File Mmc.cpp, Line 14023
21:22:12 #31 Phase 38 File dlgbrnst.cpp, Line 1655
Brennvorgang nicht erfolgreich mit 24x (3.600 KB/s)
21:22:12 #32 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Link to comment
Hallo Cat,
ich bin systemtechnisch leider total unwissend!
wie kann ich den Modus feststellen??
könnte das Problem auch an den Rohlingen liegen??
Der Brenner ist wenig im einsatz und hatte mit TDK-Rohlingen immer funktioniert, seit kurzem verwende ich BenQ-Rohlinge (waren die einzigen mit Slim-Case).
mfg
stani
Link to comment
also zu den rohingen kann ich dir nix sagen, hab immer spindeln
aber du kannst da mal googlen, da gibts auch immer herstellerempfehlungen
zu pio oder dma
da guckst du unter start-systemsteuerung-system- reiter hardware- gerätemanager
punkt IDE und dann vermutlich der secondary- eigenschaften
erweiterte einstellungen
da gibts dann die einstellung ultra dma wenn möglich und dadrunter steht was wirklich angewandt wird
lg Cat
Link to comment
Hallo Stani,
ohne jetzt dein Log analysiert zu haben, grundsätzlich 2 Dinge:
- Firmware Brenner aktuell halten!!!! immer wichtiger bei der korrekten Erkennung von neuen Medien!
- Brenntempo runterschrauben!..auch wenns kaum einer versteht, aber wieso will jeder immer X-fach brennen --> idR Schwachsinn!
=> probier mal nen anderen Hersteller (finde Verbatim immer noch sehr sehr gut; die alten goldenen Traxdata gibts ja leider nicht mehr ;) und brenne mal mit 4x
Link to comment
Hallo Overloard,
habe leider auf der Herstellerwebsite (Liteon) mit der Typenbezeichnung aus dem Gerätemanager (LTR 52327S) weder Treiber noch Firmware gefunden :(.
Könnte Nero 6 als Vollversion (bei Ebay gesehen) abhilfe schaffen???
Welche Software könnt ihr (kostengünstige, da wenig in gebrauch, dzt. keine Musik-Cds geplant) empfehlen??
mfg
stani
Link to comment
Hallo Overlord,
danke für den Link, habe ich nach meinem letzten Eintrag auch gefunden, aber leider gibts da keinen Download. Weder mit Doppelklick noch mit "Ziel speichern unter...".
Nero-express hab ich gemeinsam mit dem Brenner erhalten.
Könnte es noch andere Downloadmöglichkeiten geben? (ev. unabhängige Anbieter, oder so?)
mfg
stani
Link to comment
nur weil der 52 können sollte heißt das nicht, dass es das bringt ^^
ich brenn musik fürs auto (cd-radio und meine cds kommen mir nicht vor die tür)
immer auf 16fach und mein brenner kann auch 52fach
auch nicht jeder rohling der als 52fach deklariert ist, kann das einfach so wegstecken
auch ein guter tipp von overlord sind die rohlinge, verbatim sind einfach die besten am markt, schon vor 10 jahren so gewesen und auch heute noch
die vertrugen das 52fach brennen schon als 48fach rohlinge ^^
und du musst dir zum test ja nicht gleich zig kaufen
wegen der software, kannste mal nen anderes freeware brenntool probieren, bevor du wechselst
lg Cat
Link to comment
Hallo Cat,
danke für den Hinweis, werde bei gelegenheit mal einkaufen gehen.
Dachte übrigens auch daran das die geschwindigkeit eine Rolle spielt, aber da es bei halber geschwindigkeit auch probleme gab bin ich auf die Idee mit sonstigen problemen gekommen.
auf jeden fall Danke
Stani
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Create New...
