testperson 1.927 Geschrieben 26. August 2025 Melden Geschrieben 26. August 2025 Hi, es ist "mal wieder soweit": CITRIX | Support Zitat Affected Versions The following supported versions of NetScaler ADC and NetScaler Gateway are affected by the vulnerabilities: NetScaler ADC and NetScaler Gateway 14.1 BEFORE 14.1-47.48 NetScaler ADC and NetScaler Gateway 13.1 BEFORE 13.1-59.22 NetScaler ADC 13.1-FIPS and NDcPP BEFORE 13.1-37.241-FIPS and NDcPP NetScaler ADC 12.1-FIPS and NDcPP BEFORE 12.1-55.330-FIPS and NDcPP Zitat NetScaler ADC and NetScaler Gateway contain the vulnerability mentioned below: CVE-ID Description Pre-conditions CWE CVSSv4 CVE-2025-7775 Memory overflow vulnerability leading to Remote Code Execution and/or Denial of Service NetScaler must be configured as Gateway (VPN virtual server, ICA Proxy, CVPN, RDP Proxy) or AAA virtual server (OR) NetScaler ADC and NetScaler Gateway 13.1, 14.1, 13.1-FIPS and NDcPP: LB virtual servers of type (HTTP, SSL or HTTP_QUIC) bound with IPv6 services or servicegroups bound with IPv6 servers (OR) NetScaler ADC and NetScaler Gateway 13.1, 14.1, 13.1-FIPS and NDcPP: LB virtual servers of type (HTTP, SSL or HTTP_QUIC) bound with DBS IPv6 services or servicegroups bound with IPv6 DBS servers (OR) CR virtual server with type HDX CWE-119 - Improper Restriction of Operations within the Bounds of a Memory Buffer CVSS v4.0 Base Score: 9.2 (CVSS:4.0/AV:N/AC:H/AT:P/PR:N/UI:N/VC:H/VI:H/VA:H/SC:L/SI:L/SA:L) CVE-2025-7776 Memory overflow vulnerability leading to unpredictable or erroneous behavior and Denial of Service NetScaler must be configured as Gateway (VPN virtual server, ICA Proxy, CVPN, RDP Proxy) with PCoIP Profile bounded to it CWE-119 - Improper Restriction of Operations within the Bounds of a Memory Buffer CVSS v4.0 Base Score: 8.8 (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:H/SC:N/SI:N/SA:L) CVE-2025-8424 Improper access control on the NetScaler Management Interface Access to NSIP, Cluster Management IP or local GSLB Site IP or SNIP with Management Access CWE-284: Improper Access Control CVSS v4.0 Base Score: 8.7 (CVSS:4.0/AV:A/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:L/SI:L/SA:L) Viele Grüße Jan 2 2
