Einige Fragen
Erstellt von
ErnestoPaczona
, 06. Jan 2006 16:44
12 Antworten in diesem Thema
#1
Geschrieben 06. Januar 2006 - 16:44
Hallo!
Ich bräuchte wieder einmal eure hilfe! könnt ihr mir bitte diese Fragen beantworten!?
Ich würde diese ja in google eingeben, aber ich kenne mich nicht so gut aus und deshalb zähle ich auf euch!!
1
When selecting a desktop case style, what is the most popular form factor used today?
AT
ATH
ATX
ATZ
2
Which type of equipment is used to test high voltage devices in a PC, such as a power supply?
loopback connector
outlet tester
multimeter
wrist strap
3
Which type of connector does a modem use?
DIN
PS-2
RJ-11
RJ-45
4
Which Type of PCMCIA card is used for memory expansion?
Type I
Type II
Type III
Type IV
5
Which binary number represents the decimal number 255?
11111111
00000000
11000011
00111100
6
What is one method to change display properties in Windows 9x?
Right-click with the mouse on the Task Bar and select Display Properties from the menu.
Right-click with the mouse on the desktop and select Properties from the menu.
Right-click with the mouse on the Start button and select Properties from the menu.
Right-click with the mouse on My Computer and select Display from the menu.
7
It is hazardous to wear an anti-static wrist strap when working on which of the following pieces of equipment?
floppy drive
network card
monitor
hard drive
8
Which memory location is under the direct control of HIMEM.SYS?
conventional memory
upper memory area
extended memory
expanded memory
9
Which floppy drive is connected to the end of the cable that has a twist?
A
B
C
D
10
How should the boot IDE drive be configured?
primary master
primary slave
secondary master
secondary slave
11
Which computer boot up function moves the master boot record (MBR) into RAM?
primary bootstrap loader
file allocation table
secondary bootstrap loader
plug and play
12
What is the I/O address range of COM1?
3F8-3FF
2F8-2FF
3E8-3EF
2E8-2EF
13
How many 72-pin SIMMs does it take to fill a bank in a Pentium computer?
1
2
3
4
14
How many file allocation tables (FAT) are created when a hard drive is formatted?
1
2
3
4
15
Which DOS program defines primary and extended partitions on a hard drive?
format
fdisk
hwinfo
asd
16
Which memory mode allows one program to fail without bringing down the whole system?
conventional
protected
real
expanded
17
Which command will start an upgrade from Windows NT to Windows 2000?
D:\i386\winnt32
D:\i386\win32
D:\win\setup
D:\win\win32
18
Which Windows 9x utility is used to backup or repair the system registry?
regedit
msconfig
scanreg
sysedit
19
Which device does the POST check first?
memory
CPU
hard drive
floppy drive
20
Which type of port is a 9-pin male connector?
FireWire
parallel
serial
USB
21
What is the binary conversion of the hexadecimal number C1?
11000010
11000001
10000001
11000000
22
By default, which device uses IRQ 6?
floppy disk controller
LPT1
LPT2
real time clock
23
Which type of processor uses the socket A?
AMD
Cyrix
Intel
Motorola
24
An extended partition can be subdivided into a maximum of how many logical drives?
26
25
24
23
22
21
25
What is an acceptable way to load the System Properties applet within Windows 9x?
Start > Programs > Accessories > System Properties
Start > Settings > Control Panel > System
Start > Programs > Accessories > System Tools > Properties
Start > Settings > Control Panel > Add/Remove Programs > System Properties tab
26
What is the maximum number of devices that can be connected to a Wide SCSI-2 channel?
16
8
7
15
27
When viewing a filename, which of the following file extensions denotes an executable file?
.DOC
.SYS
.DAT
.COM
28
What are the labels on the AT power connectors that connect to the motherboard?
P1, P2
P3, P4
P6, P7
P8, P9
1
AT
ATH
ATX
ATZ
2
loopback connector
outlet tester
multimeter
wrist strap
3
DIN
PS-2
RJ-11
RJ-45
4
Type I
Type II
Type III
Type IV
5
11111111
00000000
11000011
00111100
6
7
floppy drive
network card
monitor
hard drive
8
conventional memory
upper memory area
extended memory
expanded memory
9
A
B
C
D
10
primary master
primary slave
secondary master
secondary slave
11
plug and play
12
3F8-3FF
2F8-2FF
3E8-3EF
2E8-2EF
13
1
2
3
4
14
1
2
3
4
15
format
fdisk
hwinfo
asd
16
conventional
protected
real
expanded
17
D:\i386\winnt32
D:\i386\win32
D:\win\setup
D:\win\win32
18
regedit
msconfig
scanreg
sysedit
19
memory
CPU
hard drive
floppy drive
20
FireWire
parallel
serial
USB
21
11000010
11000001
10000001
11000000
22
LPT1
LPT2
real time clock
23
AMD
Cyrix
Intel
Motorola
24
26
25
24
23
22
21
25
26
16
8
7
15
27
.DOC
.SYS
.DAT
.COM
28
P1, P2
P3, P4
P6, P7
P8, P9
Danke für eure Hilfe - Ernie
#2
Geschrieben 06. Januar 2006 - 16:46
29
Which of the following would prevent a user from moving icons on the desktop?
The user is not logged in as administrator.
The user does not have the correct permissions to move the icons.
The Auto Arrange setting is enabled.
The Auto Arrange setting is disabled.
30
What is the capability of a program to be broken into smaller parts that can be loaded as needed by the OS?
multiprocessing
multiusers
multithreading
multitasking
31
Which term describes a volume that contains identical copies of the same data?
simple volume
spanned volume
mirrored volume
RAID 5 volume
32
What is the decimal conversion of the binary number 01101010?
161
160
107
106
33
Which Windows utility views the hierarchical structure of files, folders, and drives on a computer?
File Explorer
msconfig
System Information
Windows Explorer
34
Which Windows 9x utility is used to skip a driver when the operating system fails during boot-up?
ASD.EXE
WSCRIPT.EXE
HWINFO.EXE
SYSEDIT.EXE
35
Which type of memory is used for cache memory?
DRAM
SRAM
EDO
DDR
36
Which of the following is an input device?
keyboard
printer
speakers
disk drive
37
Which DC voltages are commonly produced by ATX power supplies?
+1.8V, +5V, -5V, +12V, -12V
+1.8V, +5V, -5V, +15V, -15V
+3.3V, +5V, -5V, +15V, -15V
+3.3V, +5V, -5V, +12V, -12V
38
Which of the following correctly describes DOS?
DOS is a user-friendly, icon-based operating system.
DOS is an essential tool for IT professionals and is used extensively for troubleshooting.
DOS can run several programs at the same time since it supports multitasking.
DOS can run any sized program because it has no memory limitations.
39
Which utility is a standard text editor used to edit system configuration files such as CONFIG.SYS and AUTOEXEC.BAT?
regedit
msconfig
sysedit
ipconfig
40
How many pins are there on a floppy cable?
34
40
50
68
41
Which system condition is usually manifested by a stalling (not responding) of the system?
general protection fault
hard drive memory error
lack of virtual memory
OS version error
42
Which type of port is a 25-pin female connector?
FireWire
parallel
serial
USB
43
Which type of memory is used by RIMM modules?
RDRAM
SDRAM
EDO-RAM
DDR-SDRAM
44
Which type of memory is installed by inserting it at about a 45 degree angle, then rotating it to the vertical position?
DIMM
DIP
RIMM
SIPP
SIMM
46
Which folder permission allows users to create new files and subfolders within the folder, change folder attributes, and view folder ownership and permissions, but does not allow the user to delete the folder?
read
write
modify
list of folder contents
47
What is the correct order of execution when booting a computer into DOS?
IO.SYS, MSDOS.SYS, CONFIG.SYS, COMMAND.COM, AUTOEXEC.BAT
MSDOS.SYS, IO.SYS, CONFIG.SYS, COMMAND.COM, AUTOEXEC.BAT
IO.SYS, MSDOS.SYS, COMMAND.COM, CONFIG.SYS, AUTOEXEC.BAT
COMMAND.COM, IO.SYS, MSDOS.SYS, CONFIG.SYS, AUTOEXEC.BAT
48
Which function key, when pressed during the boot process, causes the system to proceed through CONFIG.SYS and AUTOEXEC.BAT one step at a time waiting for confirmation from the user?
F8
F6
F3
F2
49
Which Windows 2000 Pro feature is a library of hardware drivers that operate between the operating system and hardware installed on the user's system?
Hardware Abstraction Layer (HAL)
Hardware Compatibility List (HCL)
Microsoft Device Driver Library (MDDL)
Microsoft Windows 2000 Professional Device List (MDL)
50
Which DOS file contains the internal DOS commands?
IO.SYS
MSDOS.SYS
COMMAND.COM
AUTOEXEC.BAT
30
multiprocessing
multiusers
multithreading
multitasking
31
simple volume
spanned volume
mirrored volume
RAID 5 volume
32
161
160
107
106
33
File Explorer
msconfig
System Information
Windows Explorer
34
ASD.EXE
WSCRIPT.EXE
HWINFO.EXE
SYSEDIT.EXE
35
DRAM
SRAM
EDO
DDR
36
keyboard
printer
speakers
disk drive
37
38
39
regedit
msconfig
sysedit
ipconfig
40
34
40
50
68
41
OS version error
42
FireWire
parallel
serial
USB
43
RDRAM
SDRAM
EDO-RAM
DDR-SDRAM
44
DIMM
DIP
RIMM
SIPP
SIMM
46
read
write
modify
47
48
F8
F6
F3
F2
49
50
IO.SYS
MSDOS.SYS
COMMAND.COM
AUTOEXEC.BAT
#3
51
Which command transfers system files to an already formatted 3.5" diskette?
format A:
move A:
copy A:
sys A:
52
Which virtual memory file, created during the Windows 2000 Professional installation, has a default size typically set at 1.5 times the amount of system RAM?
SYSTEM.DAT
EMM386.SWP
PAGEFILE.SYS
MEMFILE.DLL
53
Which term refers to the capability of an operating system to run multiple applications at the same time?
multiuser
multitasking
multiprocessing
multithreading
54
A new PC has been assembled and the operating system loaded. However, the hard drive activity LED has failed to light up. What is the most likely cause of this problem?
hard drive has failed
hard drive LED plug not connected properly
hard drive was not installed properly
keylock switch is enabled, causing the PC to be locked
55
Which version of Windows first introduced FAT32?
Windows 98 Second Edition
Windows 98
Windows 95 OSR2
Windows 95
56
By default, which IRQ is used by the primary IDE controller?
12
13
14
15
57
Where is conventional memory located?
between 0KB and 640KB
between 641KB and 1024KB
between 1025KB and 1088KB
between 0KB and 64KB
58
In Phase 1, Preparing to Run Windows 98 Setup, the setup process creates a log file to track each step of the installation process. What is the name of this log file?
SETUPLOG.TXT
DETLOG.TXT
SETUP.LOG
INSTALLOG.TXT
59
Which statement is correct about moving or copying icons on the desktop?
When the icon on the desktop is copied, the directory for the program is also copied to the new directory location.
When an icon on the desktop is moved, the executable file of the program is also moved to the new directory location.
When an icon on the desktop is moved or copied, the program is not affected.
When an icon on the desktop is moved or copied, the executable file of the program is also moved or copied.
60
What does the red line on a cable indicate?
pin-1
pin-34
pin-40
the cable has a twist
61
If a Windows 2000 computer is configured to dual-boot, which file allows the user to select which operating system to load?
HAL.DLL
NTDETECT.COM
NTOSKRNL.EXE
BOOT.INI
62
Which registry subtree contains software configuration data about all the software that is installed on the computer?
HKEY_USERS
HKEY_CURRENT_CONFIG
HKEY_CLASSES_ROOT
HKEY_CURRENT_USER
HKEY_LOCAL_MACHINE
63
Critical files have become corrupted on the hard disk. Which Windows 2000 Professional administrative tool can be used to repair the files?
chkdsk
Emergency Repair Disk (ERD)
File Services
Computer Management
64
Which type of device is hot-swappable?
PS/2 device
parallel device
serial device
USB device
65
What is the minimum processor for a Windows 98 installation?
Pentium 133MHz
Pentium 60MHz
486DX 66MHz
386DX 33MHz
66
Which of the following is a valid DOS file name?
LOSS?.XLS
MY_DATA.DOC
WEBDESIGN.HTM
TIME/DATE.DOC
67
Which initialization file is used to load both HIMEM.SYS and EMM386.EXE?
MSDOS.SYS
CONFIG.SYS
AUTOEXEC.BAT
SYSTEM.INI
68
How many pins are there on an IDE cable?
34
40
50
68
69
Which type of connector does a network interface card use?
DIN
PS-2
RJ-11
RJ-45
70
Which Windows 9x utility is used to display the contents of the registry database?
scanreg
msconfig
sysedit
regedit
71
Which DOS command will rebuild the crucial OS master boot record?
format
fixmbr
fdisk /mbr
chkdsk
72
What is the hexadecimal conversion of the decimal number 255?
E0
EF
FF
F0
73
How thick is a Type II PCMCIA card?
3.3mm
5mm
7mm
10.5mm
74
How many characters does Windows 98 allow in extended file and folder names?
255
254
128
127
So das wärs jetzt endlich! Ich weiß es ist sehr viel, aber ihr würdet mir wirklich sehr helfen!
Danke!
Katrin
format A:
move A:
copy A:
sys A:
52
SYSTEM.DAT
EMM386.SWP
PAGEFILE.SYS
MEMFILE.DLL
53
multiuser
multitasking
multiprocessing
multithreading
54
55
Windows 98
Windows 95 OSR2
Windows 95
56
12
13
14
15
57
58
SETUPLOG.TXT
DETLOG.TXT
SETUP.LOG
INSTALLOG.TXT
59
60
pin-1
pin-34
pin-40
61
HAL.DLL
NTDETECT.COM
NTOSKRNL.EXE
BOOT.INI
62
HKEY_USERS
HKEY_CURRENT_CONFIG
HKEY_CLASSES_ROOT
HKEY_CURRENT_USER
HKEY_LOCAL_MACHINE
63
chkdsk
File Services
Computer Management
64
PS/2 device
parallel device
serial device
USB device
65
Pentium 133MHz
Pentium 60MHz
486DX 66MHz
386DX 33MHz
66
LOSS?.XLS
MY_DATA.DOC
WEBDESIGN.HTM
TIME/DATE.DOC
67
MSDOS.SYS
CONFIG.SYS
AUTOEXEC.BAT
SYSTEM.INI
68
34
40
50
68
69
DIN
PS-2
RJ-11
RJ-45
70
scanreg
msconfig
sysedit
regedit
71
format
fixmbr
fdisk /mbr
chkdsk
72
E0
EF
FF
F0
73
3.3mm
5mm
7mm
10.5mm
74
255
254
128
127
Danke!
Katrin
#4
Geschrieben 06. Januar 2006 - 16:48
Wenn man sich nicht auskennt, sollte man lernen (ganz besonders, wenn man den Stoff zum Bestehen irgendeiner Prüfung benötigt) ...
Haste Deine Midterm-Prüfung versaut, weil Du nicht googeln kannst oder weil Du keine Lust zu lernen hast ?
http://www.mcseboard...ead.php?t=79619
Ich bin S-1-5-XXX-500, ich darf das ...
#5
Geschrieben 06. Januar 2006 - 16:55
Ich dachte, dass hier sei ein Forum wo einem geholfen wird. Ja, ich kenn mich nicht so gut aus, wie manche von euch.
Ich könnte ja genauso googlen, nur wahrscheinlich würde mich dass 3 Stunden Kosten, und für euch ist dass alles eine Arbeit von 5-10 Minuten....außerdem hätte ich den nebeneffekt dass ich nicht 100%-ig sicher sein könnte...
Also bitte helft mir diese Fragen zu beantworten oder Postet lieber gar nix... Nörglereien kann ich mir überall abholen
Sollte jetzt keine Beleidigung für jemanden sein......
Übrigens, mein CISCO-Midterm-Exam hat sich nur auf Mo. verschoben, ich will eben 100%-ig sicher sein...
Bitte hilft mir..
Bitte hilft mir..
#6
Geschrieben 06. Januar 2006 - 16:56
Hi ErnestoPaczona,
wo hast Du die Fragen denn her? Das sieht mir ganz nach EDV-Grundschule 1.Klasse aus.
Wen ich mal ne ruhige Minute habe werd ich sie Dir beantworten.
Aber vielleicht solltest Du Dir mal nen Buch dazu kaufen, EDV Grundwissen oder ähnliches, da in den Fragen fast nur Grundwissen abgefragt wird, also Vorraussetzung für unseren Beruf sind
CU
Cyrus
CU
Cyrus
Security MCSA/MCSE 2000/2003 +M +S
STS
CCP
Life is not fair sometimes ... but the root password helps!
STS
CCP
#7
Geschrieben 06. Januar 2006 - 17:02
Hi Katrin,
würde dir gerne helfen... aber die Grundlagen musst du schon selber lernen.
www.google.com bzw. Sprache auf Englisch umstellen u. suchen.
Als lesen u. lernen =>
http://www.google.de...elp/basics.html
http://www.google.de.../interpret.html
http://www.google.de...finesearch.html
LG Gadget
LG Gadget
Konfuzius sagt: Fordere viel von dir selbst und erwarte wenig von den anderen. So wird dir Ärger erspart bleiben.
#8
Geschrieben 06. Januar 2006 - 17:11
Also wenn ich eure Antworten so lese, wird mir echt schlecht und mir vergeht wirklich die Lust an der EDV.
Ich wette auch ihr habt einmal klein angefangen und wart auf jede hilfe angewiesen, also wo liegt euer problem!?
Ich glaube Ihr habt recht, nur dass ich wahrscheinlich wegen euren EDV-Wahn keine Texte lesen könnt...
Ich habe geschrieben ich habe die Antworten schon, ich will mir nur sicher gehen dass diese auch Stimmen... ebenso hatte ich erwähnt dass ich gerne nur hilfreiche Antworten erwarten würde als dass jeder einfach ein wenig von seinen Senf dazu gibt.
#9
Geschrieben 06. Januar 2006 - 17:20
@ErnestoPaczona
ich glaube du hast Kohn überlesen oder ?
Wir versuchen ja unser Bestes uns gegenseitig zu helfen wenn es Probleme gibt, aber manche Dinge im Leben muß man alleine machen !
- Schule
- Führerschein etc.
Es geht hier auch nicht darum ob sich jemand die Zeit nehmen möchte um die Fragen durchzugehen, es ist hier schlichtweg falsch.
Gruß und viel Erfolg bei der Prüfung
- Schule
- Führerschein etc.
Gruß und viel Erfolg !
www.ServerHowTo.de - Das MCSEboard.de HowTo Projekt ist online!
#10
Geschrieben 06. Januar 2006 - 17:25
Lieber XP-Fan!
Da du im Zentrum des Wissens wohnst und trotzdem ein XP-Fan bist geh ich davon aus, dass ich dein voriges Post ruhigstes Gewissens ignorieren kann!
Ich werde mir die Zeit nehmen und mich für die Prüfung vorbereiten ...
Viel Spaß bei eurer "Arbeit", dieses Forum ist für mich gestorben!
Peace
Peace
#13
Geschrieben 06. Januar 2006 - 17:50
Holla, nur mit der Ruhe.
Du bist mit Fragen immer willkommen, aber das was du hier willst sprengt die Möglichketen eines Forums wie diesem ein wenig. Wenn du spezielle Problemlösungen brauchst, aber das notwendige Grundwissen mitbringst können wir dir gut helfen. Das was du hier willst können wir so nicht leisten.
Vielen Dank für dein Verständnis.
Never argue with an idíot, they drag you down to their level and beat you with experience!
